Internal Programming error in Optistruct
Hi,
I am get the below error while simulating in Optistruct, This is the first time I am getting this error and I am not able to figure it out, Kindly give me a solution. I tried all the iterations regarding this issue from altair forum , I am using 2017 version, cleared all the temporary files, element count =1166221, Hexa elements, Using NLSTAT with material and contact non linearity and pretension loading.
Starting load increment 1 Current increment 5.0000E-002
Subcase 1 Load step: 5.0000E-02
Nonlinear Error Measures Gap and Contact Element Status Maximum
Iter Avg. U EUI EPI EWI Open Closed Stick Slip Frozen Plststrn
*** INTERNAL PROGRAMMING ERROR ***
in file 'newahashc.c', at location # 993.
HSAS READ ERROR: 1538844784
OptiStruct error termination report printed to file
'20181102_Yoke_IMS_PI_Nineth_Model_64bit.stat'.
*** WARNING # 8112
Failed deleting file
'D:/Chethan/20181102_Yoke_IMS_PI_Nineth_Model_64bit/20181102_Yoke_IMS_PI_Nineth_M_1268_05_has.rs~'.
There were 1 WARNING(s) reported during the run.
Regards,
Chethan
