1 - 7 of
71
Altair Community Member
Updated by gopal_rathore
Hi,
If you are using CLOAD with a curve , this might be representing the scale factor of the force.
Updated by Altair Forum User
Hi RamGanesh,
I think what you are seeing is the scale factor. If you want to see the magnitude try this, edit the curve so that the Y value is 1 throughout and make the scale factor equal to 5050N
Check value of FE output?
