Dear All,
I am currently working on Radioss ,where i am giving CLOAD OF 5050 N but it is displayed as F= 1.00 e+00 .Kindly give ur suggestions.
Thanks
RAM
Check value of FE output?
In .out file load is correct and the analysis is running with the load i had given but only error is in displaying
If you are using CLOAD with a curve , this might be representing the scale factor of the force.
Please share out file?
ya i am using the curve for the CLOAD .
Hi RamGanesh,
I think what you are seeing is the scale factor. If you want to see the magnitude try this, edit the curve so that the Y value is 1 throughout and make the scale factor equal to 5050N
Hi Prakash,
I have tried which you had said ,there is no change.
