heat flux and heat transfer coefficient
Hi guys,
I was going through heat transfer tutorial and have a slight confusion with the following:
What is the significance of using both heat flux and convective heat coefficient here? And why heat flux is set zero? Do I need to define both of them? Or, can I use either heat flux or convective heat transfer coefficient?
The link is:
Thanks!
