Over flow component stack at %10 meshing state forever
ibrahim mücahit
ibrahim mücahit Altair Community Member
edited June 2021 in Community Q&A
When I want to cast a part with overflow it couldnt proceed. Stack at %10 meshing state forever.
I am doing low pressure casting.
I have had also "Failed to start job 'CastJob_83640' on server 'local'." problem but I fixed with selecting local paralel button. I am saying that cos it can be hint for you to understand my problem.
Thank you for your interest.
Welcome!
Answers
  • MilanRaval
    MilanRaval
    Altair Employee
    edited June 2021
    Hello,
    I am glad to hear that you were able to identify issue regarding local and parallel run. That happens due to java script failure in some system/computers. We are aware of such an issue. Apart from that if you are having run failure error issue like your other question, please refer to my response on that. I was able to run this setup successfully as well without any change.
    Regards,
    Milan Raval
  • MilanRaval
    MilanRaval
    Altair Employee
    edited June 2021
  • ibrahim mücahit
    edited June 2021
    So is it means I could not proceed this model with overflow until software is debugged? Are there any solutions now.
    Thanks for your interest.
Welcome!
Welcome!
