When I want to cast a part with overflow it couldnt proceed. Stack at %10 meshing state forever.
I am doing low pressure casting.
I have had also "Failed to start job 'CastJob_83640' on server 'local'." problem but I fixed with selecting local paralel button. I am saying that cos it can be hint for you to understand my problem.
Thank you for your interest.
I am glad to hear that you were able to identify issue regarding local and parallel run. That happens due to java script failure in some system/computers. We are aware of such an issue. Apart from that if you are having run failure error issue like your other question, please refer to my response on that. I was able to run this setup successfully as well without any change.
Milan Raval
So is it means I could not proceed this model with overflow until software is debugged? Are there any solutions now.
Thanks for your interest.
