🎉Community Raffle - Win $25
Join and Win
Contact between 2d and 3d
User: "Oguzhan Coban"
New Altair Community Member
Updated by Oguzhan Coban
Hello,
 I would like to perform a linear static analysis(stiffness) of a composite wishbone (2D Shell). The forkends and brackets are Aluminium (3D-Solid). The solid elements are glued to the 2d element. For the glue, i made a solid component and imported the assebmly from CATIA (Material information of the glue is available).  1.How can I create the contacts between the parts? 2.Is there a special case between 2d and 3d elements to create a contact 3.Is 'TIE' the right contact method? I have got another question regarding diffrent subject: 4. Is there any possibility to change the coordinate system of my assembly in Hypermesh (optistruct)?  Thanks in advance, best regards
