Data Prep and DBF files
I have an application that outputs to dbf. How do I get the dbf into Data Prep? I have tried importing with the Excel and Access channel, but DP does not recognize either. Tried ODBC, but that wants a user and password.
Janet
Janet Grimsley
VP, Business Intelligence
The Fauquier Bank
Warrenton VA
5403490215
Can you open as DB2 (dBase II)?
Chris Porthouse
Professional services
Altair
Original Message:
Sent: 09-28-2020 10:29 AM
Subject: Data Prep and DBF files
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
If I open as a DB2, Data Prep wants to set up a connection. This is just a simple .dbf file sitting on the network.
Original Message:
Sent: 9/28/2020 11:06:00 AM
Subject: RE: Data Prep and DBF files
Chris Porthouse
Altair
Original Message:
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
Chris Porthouse
Altair
Original Message:
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
I opened the dbf in Excel, so I now have an excel file. I only work with this file once a quarter. Not critical, but was curious.
Original Message:
Chris Porthouse
Altair
Original Message:
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
I opened it as a text file and it worked, although not sure that is the best choice. So far I don't see anything wrong with it.Can you open as DB2 (dBase II)?
Chris Porthouse
Altair
Original Message:
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
Original Message:
Sent: 09-28-2020 11:06 AM
Chris Porthouse
Altair
Original Message:
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
Use Monarch classic, Open database, select DBF Files (*.dbf)
Regards
Mo
Mahmoud Abdolrahim
Senior Implementation & Integration Engineer
Altair Engineering
Original Message:
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
In this situation, I think Classic is the better choice. Thanks, Mo.Hi Janet,
Use Monarch classic, Open database, select DBF Files (*.dbf)You can either port the table to DPS and modify your data in DPS or you might be able to modify it in classic.
Regards
Mo
Mahmoud Abdolrahim
Altair Engineering
Original Message:
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
Original Message:
Sent: 09-29-2020 07:31 AM
Hi Janet,
Regards
Mo
Mahmoud Abdolrahim
Altair Engineering
Original Message:
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
Chris Porthouse
Altair
Original Message:
Janet
Janet Grimsley
The Fauquier Bank
Warrenton VA
5403490215
