🎉Community Raffle - Win $25
Join and Win
Data Prep and DBF files
User: "Janet_21505"
Altair Community Member
Updated by Janet_21505
I have an application that outputs to dbf.  How do I get the dbf into Data Prep?  I have tried importing with the Excel and Access channel, but DP does not recognize either.  Tried ODBC, but that wants a user and password.
Janet ​
Janet Grimsley
VP, Business Intelligence
The Fauquier Bank
Warrenton VA
5403490215
1 - 6 of 61
    User: "CPorthouse"
    Altair Employee
    Updated by CPorthouse
    Can you open as DB2 (dBase II)?
    Chris Porthouse
    Professional services
    Altair
    Original Message:
    Sent: 09-28-2020 10:29 AM
    Subject: Data Prep and DBF files
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    User: "Janet_21505"
    OP
    Chris Porthouse
    Altair
    Original Message:
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    If I open as a DB2, Data Prep wants to set up a connection.  This is just a simple .dbf file sitting on the network.
    Original Message:
    Sent: 9/28/2020 11:06:00 AM
    Subject: RE: Data Prep and DBF files
    Chris Porthouse
    Altair
    Original Message:
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    User: "Janet_21505"
    OP
    Chris Porthouse
    Altair
    Original Message:
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    I opened the dbf in Excel, so I now have an excel file.  I only work with this file once a quarter.  Not critical, but was curious.
    Original Message:
    Chris Porthouse
    Altair
    Original Message:
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    User: "Janet_21505"
    OP
    Chris Porthouse
    Altair
    Original Message:
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    I opened it as a text file and it worked, although not sure that is the best choice.  So far I don't see anything wrong with it.
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    Original Message:
    Sent: 09-28-2020 11:06 AM
    Chris Porthouse
    Altair
    Original Message:
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    User: "Mo Abdolrahim"
    Altair Employee
    Updated by Mo Abdolrahim
    Hi Janet,
    Use Monarch classic, Open database, select DBF Files (*.dbf)
    You can either port the table to DPS and modify your data in DPS or you might be able to modify it in classic.
    Regards
    Mo
    Mahmoud Abdolrahim
    Senior Implementation & Integration Engineer
    Altair Engineering
    Original Message:
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    User: "Janet_21505"
    OP
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    Altair Engineering
    Original Message:
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    In this situation, I think Classic is the better choice.  Thanks, Mo.
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
    Original Message:
    Sent: 09-29-2020 07:31 AM
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    Altair Engineering
    Original Message:
    Janet
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    5403490215
