🎉Community Raffle - Win $25
Join and Win
mass OPtimisation by changing square size and thickness
Attached is a Hypermesh deck of a structure whose mass I’m trying to minimize. The structure has a square shaped core covered on the top and bottom by composite facesheets. Shell elements have been used for modeling. The size of the square and the thickness of its wall determine the buckling characteristics of the facesheets. I’ve modeled using a square of side 6mm and its wall thickness is 1.5 mm (shown in the snapshot below). By varying the size of this square and changing the wall thickness, I’m looking to minimse the mass, the constraint being that the buckling factor must always be greater than 1.
Could you please help me achieve my objective?
Thanks,
Kushal Agarwal.
1 - 16 of 161
