Pretension with Slide and Freeze Surfaces
Hi, I have to do a NormalModeAnalysis of an assembly. At all there are 11 parts, 4 of them are srews that are pretensioned. There is also a static load and I want to consider that some parts move under this load (small displacement).
With PretensionManager I took under account pretension and with AutoContact I create Surface-Surface Contacts (some freeze, some slide).
My pretension LoadStep is non-linear quasi-static with NLPARM. If I run the Analysis it stops with different error Messages depending on what i have given in NLPARM.
Is my Setup right for what I want to do and if it is what is the Problem? I have never done this in OptiStruct but know it from SolidThinking.
