Pretension with Slide and Freeze Surfaces
Altair Forum User
Altair Forum User
Hi, I have to do a NormalModeAnalysis of an assembly. At all there are 11 parts, 4 of them are srews that are pretensioned. There is also a static load and I want to consider that some parts move under this load (small displacement).
With PretensionManager I took under account pretension and with AutoContact I create Surface-Surface Contacts (some freeze, some slide).
My pretension LoadStep is non-linear quasi-static with NLPARM. If I run the Analysis it stops with different error Messages depending on what i have given in NLPARM.
Is my Setup right for what I want to do and if it is what is the Problem? I have never done this in OptiStruct but know it from SolidThinking.
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Wow! so much contact pairs are in your model!=)
    it's not good model for first issue=) you should do some simple test at first=)
    i will check this, but i am newbie in optistruct. )
  • Altair Forum User
    Altair Forum User
    edited October 2018
    force direction is incorrect=)
    image.png.5df27d4b2b601b0ce0d2dd2cdd6fa0b2.pngimage.png.286506e19a2ccf30707d10c32b23746f.png
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Hi, colleagues!
    why does not increment increase?
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Hi Mrt, thank you for your interest.
    Which Force do you mean? A Pretension Force?
    There is also a static load in negative z-direction, that is right
  • Altair Forum User
    Altair Forum User
    edited October 2018
    i don't know. i haven't had experience for pretension in optistruct.
    i have tried to change direction, but i had the same result. solution goes, but result i don't like.
    do you mean that we can't choose preload force direction?
  • Altair Forum User
    Altair Forum User
    edited October 2018
    It is possible to choose the orientation in Pretension Manager but I think it is set on the normal pretension of a bolt or screw by default...
    If I use a linear static load step the results are not useful, it shows me only one screw if I select displacement.
    What is your Setup in the second post?
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Hey!
    i have an idea!
    i will check it.)
    try to off static load=) to my mind you shoul switch on it on second step=) Forces apply together, although this is wrong way. )
    i will check it too!=)
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Yeah!
    pretension works properly!
    create another step and move static load.=)
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Do you run it with or without non-linear quasi-static LoadStep?
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Sorry, I can not unzip such files. Can you uploud only the .h3d file? Thank you very much!
  • Altair Forum User
    Altair Forum User
    edited October 2018
    I checked the file but stops because there is no convergence if the Loadstep reaches 1... what is the reason for that?
  • Altair Forum User
    Altair Forum User
    edited October 2018
    i don't know.
    maybe you should update your version=)
  • Altair Forum User
    Altair Forum User
    edited October 2018
    I got it, the Problem was the Error tolerance for displacement, I flaged it out and the Analysis runs.
    Thank you very much for your help Mrt!
  • Altair Forum User
    Altair Forum User
    edited October 2018
    welcome=)
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Hi too much deviation from error tolerance may result is unexpected results. Try to keep it in limits.
