The errors of running the example of OS-1393
Hi,
When I tested the example of OS-1393 in HyperWorks 2017, a lot of errors were reported. The settings in this example were followed by the document. I don't know where the problem is.
1 - 2 of
21
Thank you for your reply. Rahul R
Could you set the PARAM EXPERTNL to CNTSTB and run again shared file.
