1 - 9 of
91
Thank you @Prakash Pagadala
But the same problem occurred. I changed the constraint value that was used in the first phase. I hope it's true.
Which version are you using and what are the updates?
Please see the results which I got
I'm using the 2017.2 version.
I use volume fraction and the upper bound is 0.4 for constraint.
minimize compliance for objective.
Hi @Aslan
Is it during the first phase or 2nd phase of optimization?
Can you share the files, please?
