the 'lmxendutil' reported usage doesn't match with sum of all users checkouts
Hi, I am using lmxendutil to report and log the usage of license, but I found that the sum of the each user usage is not correct.
Here is beginning of the report message:
#lmxendutil -licstat -host XXXX -port 6200 LM-X End-user Utility v3.32 Copyright (C) 2002-2010 X-Formation. All rights reserved. ++++++++++++++++++++++++++++++++++++++++ LM-X License Server on 6200@XXXX: Server version: v4.4.9 Uptime: 5 day(s) 16 hour(s) 54 min(s) 18 sec(s) ---------------------------------------- Feature: HyperWorks Version: 13.0 Vendor: ALTAIR Start date: 2xxx-xx-xx Expire date: xxxx-xx-xx Key type: EXCLUSIVE License sharing: CUSTOM VIRTUAL 20989 of xxxxx license(s) used: <!-- see THIS --> ---------------------------------------- 21000 license(s) used by xxxxx@BBBBB [x.x.x.x] <!-- see THIS --> Login time: 2016-01-04 08:01 Checkout time: 2016-01-04 08:01 Shared on custom string: xxxxx:BBBBB 21000 license(s) used by yyyyy@CCCCC [x.x.x.x] <!-- see THIS --> Login time: 2016-01-04 08:21 Checkout time: 2016-01-04 08:21 Shared on custom string: yyyyy:CCCCC
My point is the number in '20989 of xxxxx license(s) used' is not equal to the each user sum up 21000+21000 = 42000.
It looks the reported total usage is about half of the each user usage.
3 features have this problem but others are correct, the 3 features are:
- GlobalZoneAP
- HWHyperMesh
- HyperWorks
I want to know what the relationship of the reported usage and the each user usage.
Thanks.
- GlobalZoneAP
- HWHyperMesh
- HyperWorks
#lmxendutil -licstat -host XXXX -port 6200 LM-X End-user Utility v3.32 Copyright (C) 2002-2010 X-Formation. All rights reserved. ++++++++++++++++++++++++++++++++++++++++ LM-X License Server on 6200@XXXX: Server version: v4.4.9 Uptime: 5 day(s) 16 hour(s) 54 min(s) 18 sec(s) ---------------------------------------- Feature: HyperWorks Version: 13.0 Vendor: ALTAIR Start date: 2xxx-xx-xx Expire date: xxxx-xx-xx Key type: EXCLUSIVE License sharing: CUSTOM VIRTUAL 20989 of xxxxx license(s) used: <!-- see THIS --> ---------------------------------------- 21000 license(s) used by xxxxx@BBBBB [x.x.x.x] <!-- see THIS --> Login time: 2016-01-04 08:01 Checkout time: 2016-01-04 08:01 Shared on custom string: xxxxx:BBBBB 21000 license(s) used by yyyyy@CCCCC [x.x.x.x] <!-- see THIS --> Login time: 2016-01-04 08:21 Checkout time: 2016-01-04 08:21 Shared on custom string: yyyyy:CCCCCMy point is the number in '20989 of xxxxx license(s) used' is not equal to the each user sum up 21000+21000 = 42000.
Thanks.
How to know which feature the user is using currently. The licstat command only shows the no. of license used not the feature name.
---------------------------------------- Feature: HyperWorks Version: 19.0 Vendor: ALTAIR Start date: 20xx-xx-xx Expire date: 20xx-xx-xx Key type: EXCLUSIVE License sharing: CUSTOM VIRTUAL 42000 of 197000 license(s) used: 21000 license(s) used by User1@Host1 [192.168.2.21] Login time: 2019-01-29 08:57 Checkout time: 2019-01-29 08:57 Shared on custom string: User1:Host1 21000 license(s) used by User2@Host2 [192.168.2.22] Login time: 2019-01-29 08:58 Checkout time: 2019-01-29 08:58 Shared on custom string: User2:Host2
The command is:
almutil -licstat -host server -collapse
A user can open multiple instances of HyperMesh, and still only draw 21000 features. however it must be the same username and host.
See -
HyperWorks Introduction: Altair HyperWorks Licensing
How to know, whether the above mentioned licenses are used for HyperMesh or HyperView or any other feature.
Thanks a lot for supporting me.
I am taking the output which you posted in the beginning.
From this how will you know '21000 licenses' (highlighted in blue & purple) belongs to which feature (Hypermesh or Hyperview )?
Have a look at 'Altair HyperWorks Licensing', section 'The Altair Business Model: Leveling and Stacking'
With only 21HWU I can run as many Hypermesh session as I want on my PC
/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
