TIC DOF is SPC'ed for GRID ID 6107119 component 1
Hi
When i am running a Direct Transient Solution, with Initial Velocity
The node with ID 6107119 is Constrained by 1. SPC in DOF 1 =0
2.SPCD in DOF 1 is 1.0
3. TIC (v) in DOF 1 is -2825.
Then i got the following errior
i did the same( SPC , SPCD TIC(v) for the same node in the same DOF) for number of practice models . But this is the first time i am getting this error . any body please help me.
It does not make sense to impose SPCD and TIC on the same DOF.
Can you start the time earlier so that at some point with the imposed acceleration the velocity is X (you defined)?
Sir
find the following FEM file where i have applied TIC(v), SPC ,SPCD for same node same component. It is solving .
But for few other models some times it is giving error .
Please help in solving this issue.
Can you please share us the .out file?
