I am trying to perform a 1D beam element analysis on a formula student race car. I need help regarding the application of beam end releases at the suspension nodes.
Can someone confirm this setup -
Node 1 ie. pin a = 456, node 2 ie pin b =0 - for simulating the a arm with a ball joint is correct or not?
With this, I am unable to get the rocker(bell crank to rotate).
Thank you
