🎉Community Raffle - Win $25
Join and Win
Material Non-Linearity - MATS1 or MATX02 - OptiStruct
User: "Neeraj Kumar"
Altair Community Member
Updated by Neeraj Kumar
I am doing explicit dynamic analysis in OptiStruct and there is material non-linearity. Which card should I use to define material non-linearity: MATS1 or MATX02?
Thank You.
1 - 5 of 51
    User: "PaulAltair"
    Altair Employee
    Accepted Answer
    Updated by PaulAltair
    It depends if you are using 'native Optistruct Explicit' (NLEXPL subcase) or 'Radioss Integration Explicit' (EXPDYN subcase), MATS1 is used by the former, MATX02 by the latter
    OP
    Paul Sharp, how do I specify the failure point (i.e. ultimate tensile strength and the corresponding failure strain) using MATS1 card.
    User: "PaulAltair"
    Altair Employee
    you can't really, save for setting the stress/strain curve close to flat at this point, native OS Explicit has no element erosion as yet so you can't 'fail' elements as such
    OP
    Paul Sharp,
    Suppose I specified the stress-strain curve upto "X" strain, then what will happen if the strain in the model is more than "X"?
    Will the solver do extrapolation?
    User: "PaulAltair"
    Altair Employee
    Paul Sharp,
    I think so, but to be honest I have not tried!
    From the help:
    'If the deformations go past the values defined in the table, the curve is extrapolated linearly'
