🎉Community Raffle - Win $25
Join and Win
INREL, -2, METHOD specified in HyperMesh?
User: "Blake Berk"
Altair Community Member
Updated by Blake Berk
I cannot seem to apply a method to PARAM,INREL,-2 in HyperMesh. Is there a way to do it that I'm missing?
I'm not too optimistic because I don't see the method on solver deck import...
1 - 3 of 31
    User: "Joshua Pennington"
    New Altair Community Member
    Updated by Joshua Pennington
    Illustrated from HW2021 interface:
    Did you create the Control Card > Param?
    Hold CNTRL + F, and type in PARAM and look for keyword.
    User: "Blake Berk"
    OP
    Yes. To be clear, I am looking to add the method as describe here:
    I can add the value.
    Looking for PARAM,INREL,-2,<Method>, where the Method is the load case ID for the EIGRL card. I can't seem to find an option for <Method> in the PARAM tree.
    User: "Adriano Koga_20259"
    Updated by Adriano Koga_20259
    i believe this is still not supported by HM.
    You will probably need to add this as "UNSUPPORTED PARAM" in the end, or simply BULK_UNSUPPORTED_CARD:
    PARAM,INREL,-2,something
    Or just add to your .fem file manually.
