Contact definition-RADIOSS
Hi,
I am using Hypermesh and Radioss to simulate the deformation of a sandwich panel. I have to define the contacts between ttwo panels but I am not able to do it. The contacts defined by me using Interfaces(csurfs) option is not being read during the simulation due t which the topmost panel flies off.... Only the top panel deforms... Can Someone please help me with this? Its urgent... and thanx for your replies...
Hi,
When I try to give the contact type, I have ony the following options -
Conduction, MBCNTR(rigid contact) , MBCNTDS(deformable contact), NODESET --- according to Hypermesh tutorials for RADIOSS Bulk data
I also noticed in many other places that contacts should be defined as you had said(SLIDE, STICK etc.)..
What should I do now? Waiting for your suggestions and many many thanks for the reply,
Muthukumar Maragathamayil
Yes, I know what you are talking about but I am using HM 9.0 .. Does it still have the same option for the contat types? And is there any rule that I should give only certain type like (face to face) or (element to element) for each contact type? I am a beginner and I need help in this. Expecting your reply,
hi everybody
i try to a non-linear analysis in version 10.0 ,
but when i send to radioss (bulk data) , solver gives an error.
it's saying 'Undefined SET # MSID (or SSID) on CONTACT 1'
and repeat this message for all interfaces.
when i edit the group (interfaces), i see MSID or SSID box was defined a number.
what should i do.
You should check if you reference in MSID and SSID the correct entities.
From online help:
12. The slave entity (SSID) always consists of grid nodes. It may be specified as:
• a set of grid nodes, defined using SET(GRID,..) command.
• a surface, defined using SURF command (the slave nodes are picked from the respective nodes of the SURF faces).
• a set of elements (shells or solids), defined using SET(ELEM,..) command. Slave nodes are picked from the respective nodes of the elements in the set. For 3-D solids, only nodes on the surface of the solid body are selected; internal nodes are not considered.
13. The master entity (MSID) may be defined as:
• a surface, defined using SURF command.
Hi
I have similar problem regarding contact in Radioss bulk. Problem is that field SSID which cause problems for solver is inactive (show message ERROR) and in this case I can't choose anything. I know what to do but field SSID is INACTIVE so any modification is not possible. Any suggestions ? I'm working on Hyper Works 12.0....
Without more details it will be hard to give reasonable advice. Maybe it is due to one of these:
- wrong reference of the elements in the CONTACT card
- inadequate contact type (SLIDE, STICK, FREEZE) in CONTACT CARD to prevent unconstrained movement due to applied loading
Regards,
