I tried to do volume meshing but it failed. the error as the picture. I already specify the BL at the wall and w/o BL at the inlet. Do you guys have any idea on how to fix this.
Update : I checked for free edges but no edges were found.
hi, 'im not a CFD expert, but your mesh looks to coarse, and probably this is why it is failing to tetramesh and keep the BL. Have you tried refining the outer mesh a litte bit more.
