🎉Community Raffle - Win $25
Join and Win
unit of measure
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Good morning
I wanted to ask what are the default unit of measurement in hypermesh, specifically unit of pressure and displacement.
Thanks in advance for assistance.
1 - 4 of 41
    Altair Employee
    OP
    Generally the unit system which can be followed is :
    Length: millimeter = mm
    Mass: tonne = tonne
    Time: second = s
    Pressure - MPa
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Refer below post also.
    Altair Employee
    OP
    Be careful here.  As far as I know there is no 'default' unit system in HyperMesh.  It is up to the user to make sure a consistent unit system is being used throughout the model and simulation.  For mechanical simulations the base units are length, mass, and time.  Displacements from the simulation will be in the same units as length.  This could be millimeters, inches, feet, yards, miles, furlongs, etc.  Pressure is a derived unit involving length, mass, and time.  If length is millimeters, mass is tonnes, and time is seconds then pressure will be MPa.  Another common unit system (at least in automotive) is length in millimeters, mass in kilograms, and time in milliseconds.  In this case pressure is GPa.  The key is to make sure the derived units (force, moment, pressure, stress, to name a few) are consistent with the base units (length, mass, and time).
    Altair Employee
    OP
    Thank you so much for the answers.
