Altair RISE
Nominate Yourself Now!
Saved Files Won't Open - Osx
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I am having problems opening my saved Evolve files. I keep getting the message, The file named____was not found.
To try and solve the problem I updated my software to OS X 10.10.4  and installed solidThinking 2015 4945 but the problem still occurs.
Is there as special protocol for saving files that I should know about?
Can anyone help with this problem?
Cheers. Lenin.
1 - 11 of 111
    User: "ArjunA_22390"
    Altair Employee
    Updated by ArjunA_22390
    Hi Lenin,
    1. Are you trying to open using the file menu or double clicking the file?
    2. Have you tried right click-Open with option? Do you still get the same error message?
    3. Does your file path contain any special characters or non-english characters?
    If possible, please attach a screenshot of the error message.
    Thanks,
    Altair Employee
    OP
    Hi Arjun
    Thanks for your time.
    I have tested the situation a bit further and...
    if at first I try and open a file from the finder, without Evolve Already open, I get the error message and end up with Evolve open on a new untitled project.
    If I then try and open the same file using the Mac finder window, it works fine.
    The files have normal names, Teapot Ex 1, Teapot Ex 2, Teapot Ex 3 , etc.
    If I try and open them using the file drop down menu on Evolve then I get a similar message, 'File not found. Please check file location'.
    But with Evolve already operating, I can open the same file using the Finder.
    Double clicking or right clicking in the finder give the same result.
    And right click-Open with option gives the same result.
    The problem occurs if I try and open a file without Evolve already open, and when I try and open a file using the Evolve File drop down menu when Evolve is running.
    Altair Employee
    OP
    I have come across another problem while working through the chair tutorial and am wondering how to fix it.
    I got to step 12 and when I use the Interactive Icon as instructed I don't see the default material library appear on the left of the screen where the modeling toolbar usually is. I also cannot see the default material library when using the Interactive Icon with my other models.
    Can you suggest a quick fix for this?
    The problem I mentioned previously with opening saved files still persists and I am wondering if I should uninstall solidThinking and reinstall it to solve these issues?
    Altair Employee
    Hi Lenin,
    Please go to Preferences-General and click the restore defaults button. Clicking the Interactive rendering icon should show you the material toolbar on the left side of the screen.
    As for the file not opening when double clicked or when you use right click - This is a bug. We have addressed this issue and fixed it for our 2016 release. The correct and working way of opening files is from within Evolve using File-Open.
    I ll wait for your reply.
    Altair Employee
    OP
      Thanx for that info Arjun
    I have tried restoring the defaults In Preferences, three times, including with a computer restart but still do not see anything in the material tool bar on the left of the screen. I have worked through the chair tutorial before in the 2014 version of solidThinking and remember using the interactive rendering options then. I have included here a screen shot of the materials library folder in my solidThinking folder in my Finder Window. I guess this is where the information is that is missing from my interactive rendering window. Do you have any other ideas on how I can access it?
    User: "Darren_Chilton"
    Altair Employee
    Updated by Darren_Chilton
    Hi Lenin,
    Just wondering if you click on the 'Materials' icon located toward the upper right (next to the Material Properties, Env. Properties, etc...) does a separate window open containing the material library?
    Altair Employee
    OP
    Hi Darren
    Yes, a separate window opens but there are no libraries in it. The dropdown menu has two options, New Library and Browse for Library.
    Altair Employee
    Hi,
    Let us try to check if the .ini files give any clue.
    Go to /Library/Application Support/solidThinking/2015.4945/Evolve/Config and open the Evolve.ini file with text pad. Compare your file with the file attached here and see if there is anything different w.r.t materials and libraries.
    Thanks
    Altair Employee
    OP
    <?xml version="1.0" encoding="UTF-8"?>Hi Arjun
    I get to the Application Support file but do not find any solidThinking file.
    I cannot find the solidThinking/2015.4945/Evolve files in my searches.
    Is there some where else I should be looking?
    Attached is a screen shot of the Application Support file.
    Cheers
    Lenin
    Altair Employee
    Thats very strange. How is the solidthinking folder missing?! Is the application installed on a network or a different disk?
    Altair Employee
    OP
    No, I have it installed only on my Macbook Pro.
    I do have 200 gig of the hard drive dedicated to Windows which I don't use.
    I haven't opened Windows all year.
    I am also getting a warning every time I shut down Inspire saying that it quit unexpectedly.
    I have included a screen shot of that warning message below.
    Perhaps I should uninstall and reinstall the 2015 solidThinking Suite?
    What say you?
