Effective Mass Participation
Karthic_22061
Karthic_22061 Altair Community Member
edited October 2020 in Community Q&A
Hi All,
How to output the results for Effective Mass Participation Factor in modal Analysis ?
Is it sufficient to look for the first 6 to 10 modes or a couple of hundred Hz (say 500 Hz) ?
Welcome!
Answers
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited June 2018
    Use control card PARAM,EFFMAS,YES.
    Modal mass results written to .out file.
  • gopal_rathore
    gopal_rathore Altair Community Member
    edited June 2018
    Hi All,
    Hi,
    Selection of modes depend on your area of interest in frequency range , based on these you need to observe the mode shapes and also check the mass participation in that particular mode.
    Also try to understand based on your operating condition which mode would be more severe i.e the object has the tendency to have during the operating conditions.
    Are you working on a fixture design?
  • Karthic_22061
    edited June 2018
    Thank you @gopal_rathore,
    Not fixture design.
    I came across a term  Effective Mass Participation Factor online.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2018
    Hi @Karthic
    Number of modes and EMPF are interdependent.
    Generally, a mode with higher EMPF is considered significant contributor and a cumulative EMPF more than 80% in any given response direction considered as sufficient.
  • LOKESH KATARI
    LOKESH KATARI Altair Community Member
    edited October 2018
    i am trying calculate the EMPF but its not showing anything in the out file?
    help me with this
    Thank you
  • Rahul Rajan_21763
    edited October 2018
    Additionally, you can request under OUTPUT> HGEFFMASS to write out the *.mass,*mass.mvw session files which can be directly loaded in HyperGraph to visualize the bar charts detailing on the effective mass output.
    Please also try output results in punch format and open the .pch file. Files attached for your reference.
  • LOKESH KATARI
    edited October 2018
    sir modal effective mass and mass effective are same ?
  • Rahul Rajan_21763
    edited October 2018
    Please refer attached document from help.
Welcome!
Welcome!
