Altair RISE
Nominate Yourself Now!
quasi static analysis
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I have completed a dynamic crash analysis on hypercrash and wanted to convert it to quasi-static. The dynamic analysis lasts no longer than 100 ms so I can use a low time-step.
How should I proceed to be able to use radioss for a 2  minute simulation with a higher time step? Is is possible with explicit analysis in radioss or should I use another software?
I changed the velocity to an imposed velocity and I am using no mass in order to make it quasi static. The minimum time step that I am introducing is being ignored when the calculation software starts.
Any advice?
Thanks in advance.
1 - 26 of 261
    Altair Employee
    OP
    Hi Tiago,
    You can do a quasi static analysis in RADIOSS. You can try running with a higher time step, but always check for the mass error in the engine out file.
    Can you elaborate more on the quasi static analysis you are trying to perform, that is the analysis objective.
    Altair Employee
    OP
    Hi George,
    The quasi static analysis must consist in a simulation of a compression test of a structure so I will impose a velocity in the end nodes of the structure and crush it onto a rigid wall.
    I increased the time step to 0.1 s but since the beginning of the calculation, radioss is using a time step of 9e-4 what makes the expected time raise to close to 300 hours.
    How can I impose the time step? I am using DT1 and DTIX control cards to impose minimum maximum and initial time step
    Altair Employee
    OP
    the speed must be in the order of 1 or 2 mm per second so the time step must be closer to 0.1s
    Altair Employee
    OP
    Hi Tiago,
    You can impose a time step for the run using /DT/NODA/CST keyword in the engine file.
    The format is :
    /DT/NODA/CST
    symbol_tri-boldTsca   symbol_tri-boldTmin
    Tsca is Scale factor which is 0.9 and Tmin is the target time step.
    Please go through the webinar on time step control at https://altair-2.wistia.com/medias/o0bfml9ah5
    Altair Employee
    OP
    Yes, i did that but the command is ignored.
    Altair Employee
    OP
    Hi Tiago,
    Can you share the files for reviewing (starter and engine files).
    Altair Employee
    OP
    Ok I sent via dropbox. Can you check it please?
    Altair Employee
    OP
    I have seen many times explained that the time step must be in the order of the time that a sound wave takes to cross an element. In explicit dynamic analysis that works because the crash tests takes about 100 ms to occur.
    A quasi static test with a speed of 2mm per second takes more than 1 minute so the same time step traduces on a computation time of 14 days.
    If I try to impose a minimum time step of around 0.1s it is ignored and a time step of 9e-4 is used by radioss. I don't know why.
    And even if i can impose it, will it be accurate? There's any way to make it implicit so we don't have to worry with the time step? or can radioss perform it as explicit with a high time step and still have accuracy?
    Adding a control card DT_ELTYPE_KEYWORD_IFLAG it runs for a bigger time step but the error is getting to -95% since the start
    Altair Employee
    OP
    I spotted an error in the material model.
    Corrected it and radioss runs now, the problem is that with a time step of 1ms, the mass error is getting to 5e+6.
    With this time step the calculation requires 2000 seconds to run. If i use an even smaller time step will raise the time to many hours or even more than a day
    Using a time step of 0.1 ms and reducing the time of the test i could get the calculation process down to 6000s but the mass error is still 1e+4
    Altair Employee
    OP
    Hi Tiago,
    Explicit method is commonly used in crashworthiness analysis due to its capability to solve highly non-linear problems without numerous iterations and convergence problems. However, the time step for explicit methods is limited by the time that the physical wave crosses the element. Therefore, to avoid large amount of CPU time, the explicit method is usually used for non-linear dynamic problems with a short period of simulation duration, that lasts for milliseconds normally.
    In your case the run time provided is 125 seconds which is very much high. You can give a try with implicit options available in RADIOSS, but there are chances of convergence issues.
    There are many examples and documents available on implicit in RADIOSS. Please go through it and try implementing the same.
    Altair Employee
    OP
    Hi George,
    Where can I find those documents? And thanks again for the help.
    Altair Employee
    OP
    And what if I use a higher velocity? will the results be substantially different from a low velocity compression test?
    Altair Employee
    OP
    Hi Tiago,
    There are documents and examples in Help Menu on implicit analysis in RADIOSS. Please search for implicit analysis in the Help Menu.
    There will be difference in results (deformation, stresses developed...etc)when velocity is increased.
    Altair Employee
    OP
    Hi George,
    I managed to low the simulation time. The quasi-static test is working. Thanks a lot for your advice and help.
    User: "Pohan28"
    Altair Community Member
    Updated by Pohan28
    Hi Tiago.
    Could you please share the engine 001 file?
    Altair Employee
    OP
    How much time is required to simulate an explicit analysis ?Example a crash analysis with RAM of 4gb.
    Altair Employee
    OP
    Hi,
    Normally for a crash analysis the run time will be more especially with 4gb RAM.
    But its difficult to predict the simulation time as it directly depends on the time step of the model. If the time step is low the run time can drastically increase.
    You can try with /DT/NODA/CST keyword which can reduce the run time.
    Altair Employee
    OP
    I want to know rough estimation.
    Altair Employee
    OP
    Hi,
    This is bit tougher to answer, as we cannot provide  a general answer. Node and element counts in a model also affect the run time along with the above statements.
    I suggest you to download our full car crash model and run the same. The model file can be downloaded from the link below:
    This will give you an idea on the estimated run time.
    Altair Employee
    OP
    can i have its .hm file ?
    Altair Employee
    OP
    Hi,
    Please try with the .hm attached.
    Altair Employee
    OP
    i am getting the same error with the attached model .Please help me to solve it .
    Altair Employee
    OP
    Hi,
    Please try with the attached file.
    Altair Employee
    OP
    What changes are required?Is it is ok to connect 2d mesh and 3d mesh for stress analysis?
    Altair Employee
    OP
    In the model file you have sent I have modified the output block created.
    Yes, you can connect.
    Altair Employee
    OP
    In the model, I am not getting stress on shell plate?As I want to perform stress analysis on assembly having both shell and solid parts .
