Query about OptiStruct Topology Optimization
2»
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited September 2016
    23 hours ago, Prakash Pagadala said:
    Hi Waqas,
    Can you share the model?
    Use this File Transfer LINK
    i've sent. kindly check it.
    Waqas, please share the model file not the images of the results.
    More over, the results depends on how much material you have removed during OSSmooth.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    ok. i've sent. kindly check the files.
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    Please share .fem files for better understanding.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    done. please check.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi friend, is there any update about my problem?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Waqas,
    I see some material is removed after the analysis. Make sure you move the elements of bolt area from design to non design space.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Waqas,
    Ok. thanks, but my constraint are not satisfying.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Can you load the session file HyperView and check the rotational displacement (this is what you want to optimize for) for the last iteration?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    ok. prakash. thank you so much for your cooperation.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited December 2016
    Hi All friends, I have a problem related to the constrained in topology optimization. My constrained are not satisfied in topology optimization. Anybody tell me whats the reason behind this problem? and also another problem the material is not properly removing from the low stress area. whats the matter about it, kindly help me out. Thanks
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hello,
    can you tell me? I am not getting the complete result of my topology optimization. I wanna do topology optimization of the differential case of differential gear box. My FEA analysis is fine but optimization results are showing only in blue and red region form in element density. and how to compare of our final result from our original model that how much material we can or did remove from the model?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Waqas,
    Open the ,out file in any text editor and check which constraints are violating. From this you will get to know why the constraints are violating and with what margin.
Welcome!
Welcome!
