🎉Community Raffle - Win $25
Join and Win
Import and Crashing
User: "Oswaldo Gallo"
Altair Community Member
Updated by Oswaldo Gallo
Hyperworks Student Edition importation problem
I'm having problems when I try to import files, I had followed the steps to import, starting by "File" - "Import".
Interfaz de usuario gráfica, Texto, Aplicación  Descripción generada automáticamente
 I had tried with some common files like "stp, obj, stl, etc"
Texto  Descripción generada automáticamente
The files contain a piece that I made in different programs, Blender and Inventor.
As you can see it's a simple piece.
Imagen en blanco y negro  Descripción generada automáticamente con confianza media
In this case, for the example I'm gonna use a "stp" format.
Captura de pantalla de computadora  Descripción generada automáticamente
After clicking open, the "Geometry import options" window appears. I use the default configuration
When I click "Import", it starts loading the file, but immediately it crashes, (I couldn't made a screen shot because it's too quick)
1 - 6 of 61
    User: "Paulo  Libório"
    New Altair Community Member
    Updated by Paulo Libório
    Hey Oswaldo!
    Can you go over this Altair Community blog post Achieving Optimal HyperWorks Performance and make sure you're installation complies with the guidelines described?
    Are you able to open this geometry file in another CAD reading software?
    Kind Regards,
    Paulo Libório.
    User: "Richard Ulbricht"
    Updated by Richard Ulbricht
    Thanks for the post. I run into the same problem with the latest version of Hypermesh 2023 (education). I also tried importing many different supported CAD-formats on two different computers always resulting in the same problem. I don't even get an error message, the program rapidly closes as if I ended it in the task manager. I previously used the 2022 educational version, which worked fine. But after my license expired, I was forced to update to the 2023 release.
    User: "Jandre Nel"
    Updated by Jandre Nel
    I also have the same issue with the 2023 educational version.
    User: "Daniel_20621"
    Updated by Daniel_20621
    Is there an update/solution for this issue?
    I am running into the same problems.
    User: "Dishnu D"
    Updated by Dishnu D
    I am also facing the same issue...
    Any solution so far?
    User: "Gaetan Pans_21058"
    Updated by Gaetan Pans_21058
    Hi any update on this,
    Thanks
