🎉Community Raffle - Win $25
Join and Win
Can Optistruct define a part to be rigid?
I know it can use RBE2 to let the part to be rigid.
But if today I want this component to be rigid.
Can I let the part to be rigid and not use the MPC method
I also have a question. My ram is 16GB and I use it to run, it will have the error.
 *** ERROR # 3401 ***
 System does not have enough memory available for MUMPS solver. MUMPS needs
 addtional 64328 MB. Please use a computer with bigger physical RAM.
Can I use less ram to run? I set the-maxlen
and it also failed
1 - 11 of 111
