🎉Community Raffle - Win $25
Join and Win
Can Optistruct define a part to be rigid?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I know it can use RBE2 to let the part to be rigid.
But if today I want this component to be rigid.
Can I let the part to be rigid and not use the MPC method
I also have a question. My ram is 16GB and I use it to run, it will have the error.
 *** ERROR # 3401 ***
 System does not have enough memory available for MUMPS solver. MUMPS needs
 addtional 64328 MB. Please use a computer with bigger physical RAM.
Can I use less ram to run? I set the-maxlen
and it also failed
1 - 11 of 111
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    did you use RBODY keyword?
    why did you have to change solver type to MUMPS?
    -maxlen is to limit memory for solver usage, it cannot increase your ram to 64G
    Altair Employee
    OP
    @tinh Thanks to your apply.
    I have tried RBODY, my process is set>set element, Creat>rigid body>Elements set. It will error and I didn't set any property and material of my part.
    At the second problem of the MUMPS because at this time my solution method is Non-linear quasi-static
    and I have also tried maxlen and I also set the PARAM>HASHASSM>yes, but it still error.
    User: "tinh"
    Updated by tinh
    You have to assign property and material for those elements
    Altair Employee
    OP
    But I assign them prperty and material it still error
    User: "tinh"
    Updated by tinh
    what is the error?
    Altair Employee
    OP
    @tinh I finally
    constrained hole in RBE2
    User: "tinh"
    Updated by tinh
    So why don't you let it deformable and constraint all its nodes by RBE2?
    Altair Employee
    OP
    @tinh
    Because I want it to be rigid body
    So I just constraint it's bolt hole for RBE2.
    User: "tinh"
    Updated by tinh
    please constraint all its nodes by rbe2 and rerun
    Altair Employee
    OP
    But what is the use-case?
    This may not give proper results.
    Altair Employee
    OP
    @tinh Thanks for your reply. I will try it.
    @Prakash Pagadala I use the part to contact with other part.
    And one part is the rigid other is elastic material.
    And the rigid part have the 4 bolt hole, I just give the 4 bolt RBE2.
    My analysis at run it doen't have error, but it doesn't run finish.
    So I need to use the @tinh method to constrain all nodes to be RBE2 to rerun?
    If I choose 3 parts it will show the error and just only a part will have 128937 nodes.
    Here I have  a model and how should I constrain this 2 part to be rigid.
    After that, can I use the high young's modulus to define the rigid body in non-linear quasi-static analysis?
    If my material original young's modulus is 210 GPa, I modify to 210 E^15 Pa.
    Really thanks.
