lattice analysis using pbeaml
Altair Forum User
Altair Forum User
Altair Employee
edited November 2020 in Community Q&A
Hello,everyone.
     I am a new user of the hyperworks. And I want to analysis a .iges file with many lines as you can see in the attachment. I want assign the lines with beam property.
     The problem I get is that when I use 'line mesh' with pbeaml(beam section is a circle) , bar2, and auto settings, some lines can't be assign the property correctly, as you can see in the .png file(the picture). I guess the direction of the beamsection is not correctly set, because when I analysis it by optistruct, I get an error that the 6~8 field of cbeam is zero length. But I want if there any method can generate what I want correctly.
    I want analysis a more complex lattice model(with lines in all direction), and before this I use this simple model as a practise.
    Thank you for you time, and any advise will be appreciate.
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2016
    Hi @donggua
    That is because the vector definition has zero magnitude. This causes an orientation issue.
    Can you change the orientation of the red lined vertical elements?
    Go to BEAM property>> Orientation>> change to say Z axis and check,
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2016
    Hi Prakash Pagadala
    Thank you for your help..
    I have solve this problem by  updating  bar2  with all upadate options..
    Thank you all the same..
Welcome!
Welcome!
