🎉Community Raffle - Win $25
Join and Win
Error 1487 - Optristruct
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm trying to run the tutorial on this Youtube video:
When I get to the part where I run Optistruct (+-min 24), I get the following error:
 *** ERROR # 1487 *** in the input data:
 Continuation card not allowed.
Can anyone help me?
Thank you very much!
Gonçalo
1 - 21 of 211
    Altair Employee
    OP
    Hi,
    Can you share the .fem file please?
    Altair Employee
    OP
    Hello Prakash!
    Thank you for your answer!
    The file is attached. I downloaded it from Altair's website.
    Altair Employee
    OP
    On the tutorial, on the minute mentioned above, the file is the file named: 02_analysis_complete
    Altair Employee
    OP
    Hi,
    Go to loadsteps>> Edit the first load step and remove the continuation line for STRESS and try again.
    Altair Employee
    OP
    Thank you for you answer Prakash! I can now run the simulation.
    What I can't get it's the composite failure, strain etc... I have the Global Output Request setup as told on the tutorial.
    Do you think you can further assist me?
    Altair Employee
    OP
    I think I have it now, I was running it without propper setting up.
    Sorry to bother you, thank you for your help!
    Altair Employee
    OP
    OK, thank you for the update :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
    User: "e20407"
    Altair Community Member
    Updated by e20407
    Hi,
    Sorry I don't know where to remove the continuation line for STRESS
    may you show me in a photo?
    thanks
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi @e20407
    the continuation line for STRESS is under OUTPUT
    User: "e20407"
    Updated by e20407
    Hi @e20407
    thanks
    User: "e20407"
    Updated by e20407
    Sorry
    I got one more question in the same video(23:20-23:55)
    I  do as the video and remove the continuation line for Stress
    but it didn't show up at Composite Strains and Composite Stress
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.3b1e48172c8d2c6350f80b49c371096c.png
    For PCOMPP, the SOUT field (result request) on the corresponding PLY entries should be set to YES.
    User: "e20407"
    Updated by e20407
    對於PCOMPP,相應PLY條目上的SOUT字段(結果請求)應設置為YES。
    Thank you so much.
    User: "e20407"
    Updated by e20407
    HELLO
    Can I import my 3D CAD file into Composite analysis directly? My 3D CAD has thickness, but in HyperMesh example, it’s a pure surface. Does that mean I need to make my file a non-thickness CAD?
    Hi,
    you can import 3D cad file into Hypermesh and automatically extract midsurface and assign thickness.
    3b494e3aa235cecef194d336189b55e6b26aa900.jpg?image_play_button_size=2x&image_crop_resized=960x540&image_play_button=1&image_play_button_color=7b796ae0
    Insider July Featured Tip and Trick
    https://altairuniversity.com/7196-advanced-midsurface-training-material/
    User: "e20407"
    Updated by e20407
    hello Hyperman
    I've prepared another non-thickness CAD with surface only.
    When I pre mesh, I can see the whole surface is meshed, but after I click 'return', there's some area lost the mesh
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.766b3bc12d4f51c4b1a45002fc683922.png
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.14a60c4dea1cd900be7ef0cb3f193dd2.png
     how can i fixed it?  thanks
    I think the mesh is there- it just looks like it's lost because the surface geometry is obscuring the mesh. Hide the surface or display wireframe geometry to verify.
    User: "e20407"
    Updated by e20407
    Hi Hyperman,
    1. Can I set force and SPC on the modal surface like picture below?
    (I find an example at 42:42 in this video,
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.d39ad6d9e64f34dfeb1a55ce031fe6dc.png
    2. I've already checked the mesh, and it is there. But after I put composite laminate on my model, it's broken like this
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.f1c59cff58c4682ff8a7ee3591693a08.png
    3. However, I skip this problem and proceed to click 'OptiStruct', there are lots of Error#15.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.7619958b52e524871747498e399e851c.png
    I'll be really appreciate if you can check my file in the link below
    (https://)
    Thank you
    Hi,
    1. Constraints and loads applied on single nodes will cause stress singularity. For more details refer to:
    https://www.comsol.com/blogs/singularities-in-finite-element-models-dealing-with-red-spots/
    2. and 3. are due to bad mesh. You should remesh the model  using the these tools:
    • Geom>autocleanup to clean up the geometry
    • 2D>automesh>QI  optimize (F12) to mesh using quality criteria
    • 2D>elem cleanup
    • 2D>qualityindex
    • tool>check elems>2D (F10) to check elements
    There are more then 4 million elements in the model you shared. Reduce the element count (increase element size), unless you have access to supercomputer to solve this model in a reasonable time.
    There are some great learning materials from Altair university- Practical Aspects of Finite Element Simulation is a good starting point.
    https://altairuniversity.com/free-ebooks-2/
    Check the following Youtube channels:
    Altair University
    Altair India Student Contest
    ELEATION By Apoorv Bapat
    https://altairuniversity.com/wp-content/uploads/2012/04/HM_Geometry_extract.pdf
    https://altairuniversity.com/wp-content/uploads/2014/02/HM_Automeshingintro.pdf
    https://connect.altair.com/CP/SA/training/self_paced/aero_v13/PDF/chapter4_demonstration.pdf
    The Like button is an easy way to show appreciation for a post ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
    User: "suraj123"
    Updated by suraj123
    getting this error again and again what is error and how to resolve please help
    Messages for the job:
     *** See next message about line 16 from file:
         C:/Users/Desktop/air.fem
      'STRESS(COMPLEX,ALL,CENTER,,,,,'
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Just deactivate stress & strain output from global output request. Since this is a composite material CSTRESS & CSTRAIN should be fine.
