Error 1487 - Optristruct
Hello,
I'm trying to run the tutorial on this Youtube video:
When I get to the part where I run Optistruct (+-min 24), I get the following error:
*** ERROR # 1487 *** in the input data:
Continuation card not allowed.
Can anyone help me?
Thank you very much!
Gonçalo
- Geom>autocleanup to clean up the geometry
- 2D>automesh>QI optimize (F12) to mesh using quality criteria
- 2D>elem cleanup
- 2D>qualityindex
- tool>check elems>2D (F10) to check elements
Hello Prakash!
Thank you for your answer!
The file is attached. I downloaded it from Altair's website.
On the tutorial, on the minute mentioned above, the file is the file named: 02_analysis_complete
Hi,
Go to loadsteps>> Edit the first load step and remove the continuation line for STRESS and try again.
Thank you for you answer Prakash! I can now run the simulation.
What I can't get it's the composite failure, strain etc... I have the Global Output Request setup as told on the tutorial.
Do you think you can further assist me?
I think I have it now, I was running it without propper setting up.
Sorry to bother you, thank you for your help!
OK, thank you for the update /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
For PCOMPP, the SOUT field (result request) on the corresponding PLY entries should be set to YES.
對於PCOMPP,相應PLY條目上的SOUT字段(結果請求)應設置為YES。
Thank you so much.
Hi,
you can import 3D cad file into Hypermesh and automatically extract midsurface and assign thickness.
Insider July Featured Tip and Trick
https://altairuniversity.com/7196-advanced-midsurface-training-material/
I think the mesh is there- it just looks like it's lost because the surface geometry is obscuring the mesh. Hide the surface or display wireframe geometry to verify.
Hi Hyperman,
1. Can I set force and SPC on the modal surface like picture below?
(I find an example at 42:42 in this video,
2. I've already checked the mesh, and it is there. But after I put composite laminate on my model, it's broken like this
3. However, I skip this problem and proceed to click 'OptiStruct', there are lots of Error#15.
I'll be really appreciate if you can check my file in the link below
(https://)
Thank you
Hi,
1. Constraints and loads applied on single nodes will cause stress singularity. For more details refer to:
https://www.comsol.com/blogs/singularities-in-finite-element-models-dealing-with-red-spots/
2. and 3. are due to bad mesh. You should remesh the model using the these tools:
There are more then 4 million elements in the model you shared. Reduce the element count (increase element size), unless you have access to supercomputer to solve this model in a reasonable time.
There are some great learning materials from Altair university- Practical Aspects of Finite Element Simulation is a good starting point.
https://altairuniversity.com/free-ebooks-2/
Check the following Youtube channels:
Altair University
Altair India Student Contest
ELEATION By Apoorv Bapat
https://altairuniversity.com/wp-content/uploads/2012/04/HM_Geometry_extract.pdf
https://altairuniversity.com/wp-content/uploads/2014/02/HM_Automeshingintro.pdf
https://connect.altair.com/CP/SA/training/self_paced/aero_v13/PDF/chapter4_demonstration.pdf
The Like button is an easy way to show appreciation for a post /emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
getting this error again and again what is error and how to resolve please help
Messages for the job:
*** See next message about line 16 from file:
C:/Users/Desktop/air.fem
'STRESS(COMPLEX,ALL,CENTER,,,,,'
Just deactivate stress & strain output from global output request. Since this is a composite material CSTRESS & CSTRAIN should be fine.
Hi,
Can you share the .fem file please?
