🎉Community Raffle - Win $25
Join and Win
Unable to mesh using skin depth settings
User: "Mohammad Hamza Azam"
Altair Community Member
Updated by Mohammad Hamza Azam
Hello!
What i am trying to do actually is to add skin depth to coil conductor faces for computing losses in detail instead fo simplified form. For that when I used skin depth macro and then meshed the domain nothing changes in the mesh. That's why, I am not able to access the detail losses option in winding geometry. Please help.
Thanks!
Regards
Hamza Azam
1 - 1 of 11
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    In Flux to consider the skin depth effect, you can do it using mesh generator type layers. To do it:
    Mesh >> mesh generator >> new >> select mesh generator type layers (you need to fil all the data to create the mesh generator).
    Once this is done, you assign this mesh generator to the volumes on which you want to see the skin depth effect.
    Best regards.
