Altair RISE
Nominate Yourself Now!
Option to Turn OFF generating many backup temp files when saving
User: "alpha_21885"
Altair Community Member
Updated by alpha_21885
Hi,
Whenever, I hit on save button, SL generates many backup temp files. This creates huge number of memory usage and messy file organization.
May I know how to turn off this?
1 - 3 of 31
    User: "AlessioLibrandi"
    Altair Employee
    Updated by AlessioLibrandi
    User: "Siva Matheswaran_20346"
    Altair Employee
    Updated by Siva Matheswaran_20346
    Hi Alpha,
    To stop creating new files while clicking on Save button, please turn OFF the following toggle – File > Preferences > Application > File|Save or Ctrl+S will create new database with extension.
    The above approach is used when the user manually saves the database. You can also use the auto save option to save the database at defined intervals. You can control the number of backups you wish to maintain. Once the number of saved files exceeds the number of backups, the older files will automatically be deleted.
    Thanks and Regards,
    Siva Matheswaran
    User: "alpha_21885"
    OP
    Thanks Alessio and Siva for your help. I will try the option 'Auto save' which looks good
