load time history for fatigue analysis
User: "yogeshchandra"
Altair Community Member
Updated by yogeshchandra
sir , how can i generate load-time history for the fatigue analysis ?
1 - 11 of 111
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi @yogeshchandra
    You can use MotionSolve:
    • Generating loads on a flexible body in MotionSolve via a transient MotionSolve analysis
    • Recovering stresses in OS
    • Running a fatigue analysis in OS to predict part failure
    Please refer to tutorials available on MV/MS on how to generate flexbodies and run a transient analysis with MotionSolve.
    OP
    sir, can you provide the link for the said tutorial .
    Altair Employee
    Hi @yogeshchandra
    I have shared a file to your email ID.
    Please check the same.
    User: "Subhu_21017"
    Updated by Subhu_21017
    Hi @yogeshchandra
    Hello Gents,
    Is it possible to Extract Load with Rigidbody Analysis in Motionsolve?
    Thanks in Advance!
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    Load Extraction is also possible with rigid bodies.
    e09ea081464a457fa87766bb61fed5ed03fec5c3.jpg?image_play_button_size=2x&image_crop_resized=850x480&image_play_button=1&image_play_button_color=7b796ae0
    Keshav_Webinar_Load_Extraction - Altair
    Check tutorial: mv-3030: Load export:
    User: "Subhu_21017"
    Hi Hyperman and All,
    Actually I am working on an agri-equipment and planning to investigate on it's fatigue behavior.
    It is an assembly/mechanism operated around 1500 rpm.
    I am eager to know whether there will be difference in loads extracted between rigid body analysis and flexible body analysis?
     Regards,
    Subhu
    It is impossible to answer without seeing the multibody system in question. Flexible bodies should be included to model links undergoing such severe deformations that joint locations are altered from rigid body kinematics.
    from free ebook: Practical Aspects of Multi-Body Simulation with HyperWorks
    Why Flexible Bodies?
    A traditional multi-body dynamic (MBD) analysis involves the simulation of a rigid body system under the application of forces
    and/or motions. In some cases, the flexibility of a body has a significant effect on the results of a simulation. Rigid body
    simulations do not capture such deformations and this may lead to inaccurate results. Inclusion of flexible bodies in MBD
    simulations accounts for flexibility.
    Simulation of flexible bodies in an MBD system has the following benefits:
    • Captures body deformation
    • Increases accuracy in load predictions
    • Determines the stress and/or strain distribution in a body
    • Helps generate loads needed for fatigue analysis
    However, flexible bodies introduce an additional set of equations in the system, and consequently, have a higher computational
    cost as compared to rigid body systems.
    from CAE and Multi Body Dynamics>Advanced Topics>Flexibility (attached bellow):
    High Speed Mechanisms
    At high speeds, the effects of inertial forces are large enough that the
    deformation of the links may be significan
    t. Neglecting these may well lead
    to failure of the mechanism: it may jam, vibrate too much, generate too
    much noise, and so on.
    User: "Subhu_21017"
    Hi Hyperman,
    How to extract/output modal participation factor from Motionsolve?
    TIA!
    Regards,
    Subhu
    Modal participation factors are output by default from Motionsolve when flexible bodies are included. They can be plotted in HG using either mrf of abf files.
    User: "Subhu_21017"
    Hi,
    I have a transient analysis in MBD with Flexible bodies.
    I want to evaluate the fatigue strength and damage of welds of the same in n-code.
    What are the possible ways to do it?
    Any Documents for reference would be very helpful.
    Thanks!
    Hi,
    check the resource library
    Virtual Durability Process: Bringing Together MBD, FE and Fatigue is the most relevant to your query.
    You can request more e-learning material from nCode
