Restart Error
Hi ,
I am trying to restart from the end of a successful nonlinear analysis and append new nonlinear subcase with CNTNLSUB.
I have included a new nonlinear subcase to the restart file, While doing so
A fatal error has occurred during computations:
*** ERROR # 4761 ***
The restart model is inconsistent with the original one.
Please compare the two input decks.
Please help me to restart.
Thankyou
Hi @Rahul R,
No pretension in model..
RESTARTRW and RESTARTR control card would help you to restart analysis. Please refer below post.
https://community.altair.com/community?id=community_question&sys_id=1c664cf61b2bd0908017dc61ec4bcbf4
Hi @Rahul R,
I tried using RESTARTRW and RESTARTR control cards
Help me resolve the error please
Hi ,
Thankyou
Hi @Rahul R,
Can you activate cntnlsub yes via global case control instead of activating it in subcase section of loadstep2.Then run again.
Same error persists
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
In trial1 run(write) file also, you should have global case control cntnlsub set to yes.Refer attached sample deck.
https://ftin.india.altair.com:8443/message/YYlQrjIG1AZTH0uPcUUFtR
Thank you @Rahul R, let me try
Hi @Rahul R,
I tried trial1 run(write) file having global case control cntnlsub set to yes
But facing same error
Do you have pretension in your model?
