Hi, Here the answers of your questions: 1. Short circuits: once the circuit is created; you add a resistance (with low value) in parallel between two phases (you do it for all the phases) 2. Open circuit, you use just a coil conductor (for each phase) in series with a resistance with high value (1E5 Ohm) 3. You directly connect the phase to earth 4. The same principal as in the question one, you add a resistance in parallel between two phases Best regards.
Hi,
Best regards.
