Hello!
How can we reproduce abnormal connections in the windings of a generator such as:
-short-circuites
-open turns,
-phase-to-ground,
-phase-to-phase faults (in Flux 2D)
Best regards.
Hi, Here the answers of your questions: 1. Short circuits: once the circuit is created; you add a resistance (with low value) in parallel between two phases (you do it for all the phases) 2. Open circuit, you use just a coil conductor (for each phase) in series with a resistance with high value (1E5 Ohm) 3. You directly connect the phase to earth 4. The same principal as in the question one, you add a resistance in parallel between two phases Best regards.
Thank you very much
I will let you know if everything went well.
Best reguards.
You are welcome.
