🎉Community Raffle - Win $25
Join and Win
Abnormal connections in the windings of generators
User: "Alef"
Altair Community Member
Updated by Alef
Hello!
How can we reproduce abnormal connections in the windings of a generator such as:
-short-circuites
-open turns,
-phase-to-ground,
-phase-to-phase faults (in Flux 2D)
Best regards.
1 - 3 of 31
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    Here the answers of your questions:
    1. Short circuits: once the circuit is created; you add a resistance (with low value) in parallel between two phases (you do it for all the phases)
    2. Open circuit, you use just a coil conductor (for each phase) in series with a resistance with high value (1E5 Ohm)
    3. You directly connect the phase to earth
    4. The same principal as in the question one, you add a resistance in parallel between two phases
    Best regards.
    User: "Alef"
    OP
    Updated by Alef
    Thank you very much
    I will let you know if everything went well.
    Best reguards.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    You are welcome.
    Best regards.
