🎉Community Raffle - Win $25
Join and Win
COPYING CONTACTS
User: "mpvnaresh"
Altair Community Member
Updated by mpvnaresh
Hi
I have two components with contacts between them . Initially for simplicity i have taken only a segment .
Now i need to consider the 360 degrees model
I am using transformation tool (tools -->transformation tool) for repeating the elements in a circular or linear pattern .
After doing that i had to create the contacts between the newly created elements which is very time taking ( contact surfaces around 200 . contacts around 50 in number )
so is there any way to make it simple(where contacts also can be transformed along with the elements )
1 - 5 of 51
    User: "mpvnaresh"
    OP
     If any body have an idea please share....It really help in saving a lot of time for me ..
    User: "tinh"
    Updated by tinh
    Could I see your model?
    User: "mpvnaresh"
    OP
    User: "tinh"
    Updated by tinh
    Below is my experience, pls try:
    - save initial model to file 01
    - rotate elems (don't duplicate)
    - save as file 02
    - rotate... save as ....
    Once you get 10 files, import them to 1 file & equivalence nodes, organize elems.
    User: "mpvnaresh"
    OP
    thank you verymuch .....it helps me a lot ....
