Hi
I have two components with contacts between them . Initially for simplicity i have taken only a segment .
Now i need to consider the 360 degrees model
I am using transformation tool (tools -->transformation tool) for repeating the elements in a circular or linear pattern .
After doing that i had to create the contacts between the newly created elements which is very time taking ( contact surfaces around 200 . contacts around 50 in number )
so is there any way to make it simple(where contacts also can be transformed along with the elements )
