COPYING CONTACTS
mpvnaresh
mpvnaresh Altair Community Member
edited October 2020 in Community Q&A
Hi
I have two components with contacts between them . Initially for simplicity i have taken only a segment .
Now i need to consider the 360 degrees model
I am using transformation tool (tools -->transformation tool) for repeating the elements in a circular or linear pattern .
After doing that i had to create the contacts between the newly created elements which is very time taking ( contact surfaces around 200 . contacts around 50 in number )
so is there any way to make it simple(where contacts also can be transformed along with the elements )
Welcome!
Answers
  • mpvnaresh
    edited June 2019
     If any body have an idea please share....It really help in saving a lot of time for me ..
  • tinh
    tinh Altair Community Member
    edited June 2019
    Could I see your model?
  • mpvnaresh
    edited June 2019
  • tinh
    edited June 2019
    Below is my experience, pls try:
    - save initial model to file 01
    - rotate elems (don't duplicate)
    - save as file 02
    - rotate... save as ....
    Once you get 10 files, import them to 1 file & equivalence nodes, organize elems.
  • mpvnaresh
    edited June 2019
    thank you verymuch .....it helps me a lot ....
Welcome!
Welcome!
