Altair RISE
Nominate Yourself Now!
Compression only elements
User: "lucariga"
Altair Community Member
Updated by lucariga
Hi,
I'm tring to model a semplified 2D pin element using RBE and CBAR with rotational dof release along the normal to plane.
Due to geometrical and load condition the RBE express a tension/compression on dipendent nodes.
my question is: si possible using an element (such as rbe) that is rigid in compression and not rigid (deactivated?) in traction?
1 - 4 of 41
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Try PBUSD1D of type SPRING . You can specify different tables for spring stiffness in tension and/or compression. And specify very high stiffness for compression.
    User: "lucariga"
    OP
    Updated by lucariga
    Hi Rahul,
    I'm a new user on Altair, could you provide a simple example (a model) of this method?
    thanks
    Please refer attached fem deck to get idea.
    User: "Merula_20758"
    Updated by Merula_20758
    Hi!
    I digged a bit deeper into it and maybe this can be useful.
    So if I am not wrong on this, first thing for this to work is, that you have a non-linear subcase (non linear static for example) with a NLPARM card.
    I went into some problems when defining the stiffnes to be completely zero for tension, but that seems to be a model issue only related to the simple example.
    I attached the modified .fem file for future reference (also for mysel if I want to look it up again ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' /> )
    Have a nice day!
