Tecplot file generation
User: "cjc_21934"
Altair Community Member
Updated by cjc_21934
Hi all,
I am trying to extract temperature results from an Acusolve run for further simulation elsewhere, similarly to tutorial CFD-1700.
Is the Tecplot result file generated in AcuOut? I couldn't find a way to do it; Table/ Surface Output (Nodal)  gives me no variables.
Regards,
Cristian
1 - 1 of 11
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    AcuOut can generate test file. I guess that suffices as Tecplot input.
    If you are not getting Table/Surface Output-Nodal, you enable it by Surface > Surface Outputs > Nodal Time Frequency = 10
    or another value that makes sense for your case.
