CBUSH spring benchmark
Dear all,
before inserting the CBUSH spring into my model I decided to do a simple benchmark which in the end turned out unlogical (for me).
My benchmark model consists of CBUSH element - one end is fixed (1-6 DOF) while the other is loaded with a force of magnitude = 1 (axially in tension), 1D. I am using a PBUSH property with stiffness K = 1 (for axial direction, other K's are defined as RIGID).
The results yield a displacement of 10E-4 and not 1, as I expected. I am assuming Force = Stiffness x Displacement.
What did I miss here?
Thank you all for your time and help!
Thank you for your answer!
I made a new model with same inputs (K = 1, F = 1) and now the results yield '1'. This is correct. However I cannot find what was wrong with my old model... Please see below the input deck.
This is my input file:
SUBCASE 1
LABEL displacement
ANALYSIS STATICS
SPC = 1
LOAD = 2
DISPLACEMENT(H3D,ROTA) = ALL
BEGIN BULK
CORD3R 1 1 2 3
GRID 1 0.0 0.0 0.0
GRID 2 0.0 0.0 10.0
GRID 3 1.0 0.0 0.0
GRID 4 0.0 0.0 0.0
GRID 5 0.0 0.0 10.0
CBUSH 1 1 4 5 1
PBUSH 1 KRIGID RIGID 1.0 RIGID RIGID RIGID
SPC 1 4 1234560.0
FORCE 2 5 01.0 0.0 0.0 1.0
ENDDATA
Any thoughs?
oh, reaffirm your input values
displacement is 1 always. i tested it
