How can i know the diameter of RBE3 bolts that i choose ?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
Please How can i know the diameter of bolts that i choose ?
i can not find the diameter column to know it !
Best
1 - 11 of 111
    Altair Employee
    OP
    Hi,
    Dia of the Bolt is same as dia Hole. So, use F4 Key to find out the dia of Hole.
    thank you
    Altair Employee
    OP
    Thanks Premanand,
    But i have used RBE3 elements for the fixation without make holes
    what i can do in this case ?
    Thanks
    Altair Employee
    OP
    Sorry, i didn't get you. You have created bolt connection between two holes right?
    Thank you
    Altair Employee
    OP
    you can create bolt connection using RBE3 between two elements
    Thanks
    Altair Employee
    OP
    yes i know that, but why are you creating bolt connection between two elements? bolts are created between two components to hold them together.
    Thank you
    Altair Employee
    OP
    yes that is what i did
    i have created bolts between two elements of two componenets
    Thank you
    Altair Employee
    OP
    Please understand, Bolt is created between two 'Holes' of different components, not between two elements.
    Thank you
    Altair Employee
    OP
    Hi,
    You may wish to create RBE3 between two components instead of in between 2 holes, that's fine.
    But why you want to know the Dia of RBE3 element. RBE 3 is a rigid element &  will not deform with even infinite forces. If you are interested to know the stress on joint/link (represented by RBE3 by you earlier) make RBE3 web for each component & connect it via BAR element on which you can give dia.
    Hope it helps.
    Altair Employee
    OP
    Also for most practical cases, bolts are last to fail, before that material of component fails. That is why, usually bolts are not modeled and rigid RBE2 and RBE3 elements are used.
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Wrong.
    RBE3 is not rigid, it's deformable
    Altair Employee
    OP
    Agree..
    RBE2 imposes stiffness, but RBE3 is an interpolation element.
