Please How can i know the diameter of bolts that i choose ?
i can not find the diameter column to know it !
Best
Dia of the Bolt is same as dia Hole. So, use F4 Key to find out the dia of Hole.
thank you
Thanks Premanand,
But i have used RBE3 elements for the fixation without make holes
what i can do in this case ?
Thanks
Sorry, i didn't get you. You have created bolt connection between two holes right?
Thank you
you can create bolt connection using RBE3 between two elements
yes i know that, but why are you creating bolt connection between two elements? bolts are created between two components to hold them together.
yes that is what i did
i have created bolts between two elements of two componenets
Please understand, Bolt is created between two 'Holes' of different components, not between two elements.
You may wish to create RBE3 between two components instead of in between 2 holes, that's fine.
But why you want to know the Dia of RBE3 element. RBE 3 is a rigid element & will not deform with even infinite forces. If you are interested to know the stress on joint/link (represented by RBE3 by you earlier) make RBE3 web for each component & connect it via BAR element on which you can give dia.
Hope it helps.
Also for most practical cases, bolts are last to fail, before that material of component fails. That is why, usually bolts are not modeled and rigid RBE2 and RBE3 elements are used.
Wrong.
RBE3 is not rigid, it's deformable
Agree..
RBE2 imposes stiffness, but RBE3 is an interpolation element.
