1 - 11 of
111
Hi,
You may wish to create RBE3 between two components instead of in between 2 holes, that's fine.
But why you want to know the Dia of RBE3 element. RBE 3 is a rigid element & will not deform with even infinite forces. If you are interested to know the stress on joint/link (represented by RBE3 by you earlier) make RBE3 web for each component & connect it via BAR element on which you can give dia.
Hope it helps.
Hi,
Dia of the Bolt is same as dia Hole. So, use F4 Key to find out the dia of Hole.
thank you
