Can I request specific grid displacements to be written to the .out file?
Hello,
I'm currently simulating various linear static stiffness tests for different iterations of a fairly complex model. In order to keep track of the stiffness changes for each iteration, I'm recording the displacement at the load points for each load step. The fastest way I've found to do this is to open the .h3d file in HyperView and manually query the displacement at a specific node, switch load case, select a different node, and so on. As you can imagine, this is a very time consuming process.
It would be great if there was a way to request that the displacement of specific grid ID's in specific load steps are recorded to the .out file, or another text file. Is there any way to set this up in Hypermesh?
Best Answer
Hi,
Try this way
- In Hypermesh, create an entity set of concerned grids (panel Analysis>entity set)
- Activate control card GLOBAL_OUTPUT_REQUEST > DISPLACEMENT (panel Analysis>control cards)
- On DISPLACEMENT card, select "FORMAT" as "OPTI", "OPTION" as "SID" and "SID" as the created entity set
If your *.fem file is "sample.fem"
then displacement of the grids will be written to a file named "sample.grid". Check it!
2
Answers
Hi,
Try this way
2 -
tinh said:
Hi,
Try this way
the OPTI output with a SET is the best way, as pointed by tinh.
Another option that you would have is to use Altair Compose to easily extract these data and apply some math directly. I'm not sure if you're familiar with Compose.
0 -
tinh said:
Hi,
Try this way
Hi tinh,
This worked very well. I can import the data now from the text file to excel and automatically sort it for the displacements I'm looking for.
Cheers!
0
