Altair RISE
Nominate Yourself Now!
3D meshing basic problem
User: "Rahul_P1"
Altair Employee
Updated by Rahul_P1
Hello together,
I am using the 3D mesh for the first time and have some questions how to do it corretly.
Basicly I have 2 components which origin is an imported *.iges geometry. The first picture shows the component with a special shaped hole.
The second shows the part which shell be integrated in that hole
and the third shows the combined components.
so far I uses tetra mesh for each component individually. As you can see in the third picture there are some areas which overlap.
1. What can I do against those overlapping areas?
2. In general I want to have some areas of two components which are connected an some which move freely. How do I manage that?
Hope you can help me.
1 - 8 of 81
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Hi Student_1739,
    I currently understand the issue to be that you need to have a matching mesh between the two components.
    Here is a similar model,
    Tetramesh only one of the components first
    Then extract faces from this component using tool > faces
    Then use tool > project to project only those face elements that need to match to the other unmeshed component
    Then use volume tetramesh > match existing mesh
    Or use automesh and mesh all the other surfaces except the surface with the projected elements to create a closed volume and then tetramesh this volume. this will create matching mesh between the two components.
    To have certain regions fixed and certain other regions moving freely, after creating a matching mesh as above you can then proceed to create and define contact surfaces, contact interfaces can then be defined at required regions with fixed or sliding properties.
    you could also perhaps try the mesh imprint after creating 2d meshes for components, imprint to ensure the meshes match and then proceed to tetramesh,
    You may also have to ensure the geometry is edited so as to have matching surfaces so the mesh edges are confined into the surface and do not extend along the surface and hence imprintable or that we are able to match them.
    for the above example the inner component was edited so that there are matching surfaces as below.
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    isn't there a way to define that two touching surfaces are connected before starting the meshing process. otherwise it would be a lot of work to select each element. especially when it is inside the yellow component like in my problem.
    what I did so far was:
    1. 2D automesh the inner component, than tetra mesh.
    2. find faces (displayed), resulting in a new component 'faces'
    3. project all those elements to the component 'faces'
    4. tetramesh the outer component.
    it seems there are still some small clashing areas. I used the same size/element properties
    should I project to another component like the outer one?
    How do I define contact surfaces?
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Student_1739
    The step 3 above should be to project the elements you want to match to the outer component surface.
    When there are two adjoining surfaces A and B of solids whose mesh has to match, solid 1 and solid 2, just mesh solid 1, extract the face elements of surface A , project the face elements to surface B of solid 2, them mesh solid 2
    You can use Geometry > boolean if you have solids in order to combine the two solids so that they become one volume and there is full connectivity between the two bodies when you mesh.
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    ok.
    the problem is, that I only can choose onesurface of the outer component. so the projection is not working.
    I just tried it again with an other surface. now it seems to work but as you can see in the close up it didn't work for the hole mesh
    the problem is based on the geometry.
    as you can see in the pictures, the lines of the two components are not the same.
    is there a way to edit this before I proceed with the tetramesh and the face projection??
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Student_1739
    Please send the model using the dropbox below,
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    Thanks ,
    I have sent you the modified models,.
    Steps
    Deleted the matching surfaces from the comp id 13
    Dduplicated the matching surfaces from comp id 2 and organized into 13
    surface meshed 13 while keeping similar bounding lines between 2 and 13
    selected nodes on the surface of 13 and associated to respective surfaces of 2
    surface meshed 2
    tetrameshed 2 and 13
    Please check these models and see if it satisfies the requirement
    User: "Rahul_P1"
    Altair Employee
    OP
    Updated by Rahul_P1
    thank you once again. it's working!
    User: "Pandurang"
    Altair Community Member
    Updated by Pandurang
    Hi Rahul
    @Rahul Ponginan
    Nice Info
    I have similar issue.
    I want to create match mesh between 2 Component (but matching surface having different area)
    and there is some gap between them
    i writing the script for this one.
    Step i have done till now:
    1. create mesh on one surface .
    2  project mesh.
    3. trim the surface (if one surface is small than other) using outside nodes
    4. then create 2D Mesh remaining surface except project surf one : But the problem is mesh connectivity issue
    how to overcome this issue?
    Any idea
    Thanks
    PD
